[mapguide][MG106][Modified] Display of map height in status bar incorrect with DWF Viewe...
Alain Lebatard
alain.lebatard at autodesk.com
Wed Mar 15 14:36:34 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG106
Type:
Defect
Artifact ID:
MG106 (Display of map height in status bar incorrect with DWF Viewer-based web layouts)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
The DWF viewer surround was using DWF viewer APIs that returned view extent, not map extent.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
