[mapguide][MG111][New] Scale ranges parsed incorrectly for grid and drawing layers ...
Traian Stanev traian.stanev at autodesk.com
Wed Mar 15 16:22:33 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG111
Type
 Defect
Artifact ID
 MG111 (Scale ranges parsed incorrectly for grid and drawing layers in MgLayer)
Reported by
 Traian Stanev
 traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Summary set to new value
- Platform set to new value
  All
- Steps to Reproduce set to new value
  Raster layers do not display at all after recent fixes to correctly check scale ranges. Drawing layers may or may not display...
- Version set to new value
  1.0.0
- Priority set to new value
  P2
- Component set to new value
  All
- Subcomponent set to new value
  General
- Artifact Status set to new value
  New
- Target milestone set to new value
  1.0.0
- Artifact created
- Defect Severity set to new value
  High
- Description set to new value
  Scale ranges are not parsed and initialized correctly for Drawing and Grid MDF layers. Handling for GridLayers was missing while scales were not initialized for DrawingLayers resulting in erratic behavior in the case where the layer uses defaults (i.e. not explicitly set in the layer definition XML).
- Operating system set to new value
  All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
