[mapguide][MG114][New] & Character in URL Nullifies Tool Tip
Andrew Morsell amorsell at spatialgis.com
Wed Mar 15 17:33:33 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG114
Type
 Defect
Artifact ID
 MG114 (& Character in URL Nullifies Tool Tip)
Reported by
 Andrew Morsell
 amorsell (amorsell at spatialgis.com)
New artifact details:
- Subcomponent set to new value
  AJAX Viewer
- Artifact created
- Steps to Reproduce set to new value
  Create a URL string with a & character and open that map.
- Summary set to new value
- Description set to new value
  Only applies to AJAX viewer, works as expected in DWF viewer.  If a & character is used in a Feature URL in a layer definition, the entire Tool Tip is not rendered.  This can be worked around by substituting & for the & character.  This has only been confirmed with the .NET web extensions.
- Operating system set to new value
  Windows XP
- Component set to new value
  Viewer
- OS Distribution and Version set to new value
  XP SP2
- Artifact Status set to new value
  New
- Platform set to new value
  PC
- Version set to new value
  1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
