[mapguide][MG115][New] Buffer is not using great circle distances on LL maps
Alain Lebatard
alain.lebatard at autodesk.com
Wed Mar 15 20:37:29 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG115
Type
Defect
Artifact ID
MG115 (Buffer is not using great circle distances on LL maps)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Summary set to new value
- Subcomponent set to new value
General
- Steps to Reproduce set to new value
1) Create a map with LL84 data and LL84 coordinate system.
2) Create a web layout from the map
3) Try a buffer command.
Note that by tracing through the code that the buffer is not doing a great circle calculation for distances. (Put a breakpoint on the constructor for GreatCircleBufferUtil; it should be hit).
- Component set to new value
Web Server Extensions
- Platform set to new value
All
- Version set to new value
1.0.0
- Description set to new value
"Buffer is not using great circle distances on LL maps"
- Priority set to new value
P2
- Defect Severity set to new value
High
- Artifact Status set to new value
New
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
