[mapguide][MG115][Modified] Buffer is not using great circle distances on LL maps
Alain Lebatard alain.lebatard at autodesk.com
Wed Mar 15 20:42:48 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG115
Type:
Defect
Artifact ID:
MG115 (Buffer is not using great circle distances on LL maps)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution Description set to new value:
The buffer command now uses great circle calculation for geographic/projected coordinate systems, and linear calculation for aribtratry X-Y coordinate systems.
This submission fixes a couple other bugs in the process.
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
