[mapguide][MG116][New] Update Site Admin to use generic application name
Louise Watson
louise.watson at autodesk.com
Thu Mar 16 09:48:33 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG116
Type
Task
Artifact ID
MG116 (Update Site Admin to use generic application name)
Reported by
Louise Watson
louisewatson (louise.watson at autodesk.com)
New artifact details:
- Description set to new value
This task entails updating Site Admin to use a generic application name which will not need to be customized for the Open Source/Enterprise versions of the product. This implies the following changes:
1. The name of the application will be "MapGuide Site Administrator" for both products.
2. In th About Box, the server is given the generic name of "MapGuide Server".
3. The Autodesk logo does will not appear in the Enterprise product.
4. The fill color used on the banner for each product is set to dark blue. Previously, in ECO15082, dark blue was specified as the Open Source fill color and purple was the the Enterprise fill color.
The code defining values for each of the attributes of the product look will remain in resizableadmin.php so that it is easy to change these values in the future.
- Artifact created
- Summary set to new value
- Task Priority set to new value
High
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
