[mapguide][MG117][New] Problem with selection in Load Packages table of Site Admin
Louise Watson louise.watson at autodesk.com
Thu Mar 16 10:19:00 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG117
Type
 Defect
Artifact ID
 MG117 (Problem with selection in Load Packages table of Site Admin)
Reported by
 Louise Watson
 louisewatson (louise.watson at autodesk.com)
New artifact details:
- Description set to new value
  The Load Packages table of Site Admin has a radio button selector which determines which log file is to be viewed when the "View Log" button is pushed.  However, the "View Log" display shows the wrong log file when the selector has been used to change the current selection.
- Artifact created
- Priority set to new value
  P2
- Version set to new value
  1.0.0
- Subcomponent set to new value
  Map Admin
- Steps to Reproduce set to new value
  1. Invoke Site Admin.
2. Go to the "Manage Packages" page.
3. Note the current package selection and select another package.
4. Hit the "View Log" button.  Notice that the displayed log is for the original selection.
- Status Explanation set to new value
  This is a very annoying bug;however, there is a workaround.  That is to select the desired package, leave the Manage Packages page and return so that the original selection is the desired selection.
- Summary set to new value
- Artifact Status set to new value
  New
- Platform set to new value
  All
- Operating system set to new value
  All
- Defect Severity set to new value
  High
- Resolution Description set to new value
  The fix is easy.  The problem was the the script which creates the window for viewing the package log used the wrong id value to indentify the desired log.
- Component set to new value
  Web Server Extensions
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
