[mapguide][MG118][New] Problem with selection in Load Packages table of Site Admin
Louise Watson
louise.watson at autodesk.com
Thu Mar 16 10:21:38 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG118
Type
Defect
Artifact ID
MG118 (Problem with selection in Load Packages table of Site Admin)
Reported by
Louise Watson
louisewatson (louise.watson at autodesk.com)
New artifact details:
- Defect Severity set to new value
High
- Summary set to new value
- Artifact created
- Status Explanation set to new value
This is a very annoying bug;however, there is a workaround. That is to select the desired package, leave the Manage Packages page and return so that the original selection is the desired selection.
- Subcomponent set to new value
Map Admin
- Platform set to new value
All
- Steps to Reproduce set to new value
1. Invoke Site Admin.
2. Go to the "Manage Packages" page.
3. Note the current package selection and select another package.
4. Hit the "View Log" button. Notice that the displayed log is for the original selection.
- Description set to new value
The Load Packages table of Site Admin has a radio button selector which determines which log file is to be viewed when the "View Log" button is pushed. However, the "View Log" display shows the wrong log file when the selector has been used to change the current selection.
- Component set to new value
Web Server Extensions
- Resolution Description set to new value
The fix is easy. The problem was the the script which creates the window for viewing the package log used the wrong id value to indentify the desired log.
- Version set to new value
1.0.0
- Priority set to new value
P2
- Operating system set to new value
All
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
