[mapguide][MG120][New] Line does not draw when using the distance tool
Andrew Morsell
amorsell at spatialgis.com
Thu Mar 16 11:33:45 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG120
Type
Defect
Artifact ID
MG120 (Line does not draw when using the distance tool)
Reported by
Andrew Morsell
amorsell (amorsell at spatialgis.com)
New artifact details:
- Artifact Status set to new value
New
- Summary set to new value
- Subcomponent set to new value
Viewer Command
- Description set to new value
When using the distance tool in either the AJAX or DWF viewer, the redline for that path is not rendering to the map. The Measure layer doeas appear in the layer legend, however. Perhaps a coordinate system problem. Map in this case is assigned WA State Plane NAD83, Feet.
- Steps to Reproduce set to new value
Use the measure tool in a map assigned a non LL or Arbitrary coordinate system
- OS Distribution and Version set to new value
XP SP2
- Defect Severity set to new value
Medium
- Platform set to new value
PC
- Component set to new value
Viewer
- Operating system set to new value
Windows XP
- Artifact created
- Version set to new value
1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
