[mapguide][MG122][New] Fix minor Linux build issues
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Mar 16 11:50:15 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG122
Type
 Task
Artifact ID
 MG122 (Fix minor Linux build issues)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Artifact created
- Summary set to new value
- Priority set to new value
  P3
- Task Priority set to new value
  Medium
- Artifact Status set to new value
  New
- Description set to new value
  There are a couple of minor Linux build issues that still need to be addressed.
1/ Fix the compiler version checking in configure.in
- The code that currently tries to do it is the following:
  gcc --version > gccver.txt
  sed -e '/^gcc version 3.2/ p' gccver.txt > gcc32.txt
It doesn't work correctly: it always thinks you're running gcc 3.2 or less...
- I believe this code was copied from the DWF configure.in files.  It also doesn't work correctly there, and should be fixed there as well.
2/ Remove the following Makefiles:
Oem/DWFTK7.1/Makefile
Oem/DWFTK7.1/develop/Makefile
Oem/DWFTK7.1/develop/global/Makefile
Oem/DWFTK7.1/develop/global/src/Makefile
These should be auto-generated from the Makefile.am's.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
