[mapguide][MG125][New] Change layer template used in code samples for Dev Guide.
Philip Sharman
philip.sharman at autodesk.com
Thu Mar 16 13:03:14 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG125
Type
Defect
Artifact ID
MG125 (Change layer template used in code samples for Dev Guide.)
Reported by
Philip Sharman
philipsharman (philip.sharman at autodesk.com)
New artifact details:
- Priority set to new value
P5
- Platform set to new value
All
- Component set to new value
Web Server Extensions
- Resolution set to new value
Submitted
- Operating system set to new value
All
- Artifact created
- Version set to new value
1.0.0
- Artifact Status set to new value
New
- Subcomponent set to new value
N/A
- Description set to new value
Updated layerdefinitionfactory.php to support calls from sample code placed in directories other than the 'mapguide' virtual directory.
- Steps to Reproduce set to new value
Install and run the Dev Guide samples that are on the OSGeo web site.
- Summary set to new value
- Defect Severity set to new value
Low
- Documentation Notes set to new value
1) Changed layerdefinitionfactory.php so that instead of using '../viewerfiles' it uses '/mapguide/viewerfiles'. This lets it be called from sample code that can be installed in e.g. a 'devguide' directory under the 'www' directory, instead of having to be installed directly in 'www'. This lets us keep all the sample code for the Developer's Guide better organized.
2) Also fixed a typo in the 'geometry' paramter.
This change is being made to the 1.0.0 branch as well as to the main trunk.
- Submission Reviewed set to new value
No
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
