[mapguide][MG128][New] Save viewer options dsiplay script errors in task pane
Alain Lebatard
alain.lebatard at autodesk.com
Thu Mar 16 20:10:18 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG128
Type
Defect
Artifact ID
MG128 (Save viewer options dsiplay script errors in task pane)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Description set to new value
The viewer options save button cause the task pane to display script errors
- Component set to new value
Web Server Extensions
- Artifact Status set to new value
New
- Version set to new value
1.0.0
- Artifact created
- Defect Severity set to new value
High
- Summary set to new value
- Platform set to new value
All
- Subcomponent set to new value
Viewer Command
- Steps to Reproduce set to new value
Run the "viewer options" command
Save
==> task pane contains displays server-side script error
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
