[mapguide][MG109][Modified] Great Circle buffer returns incorrect results
Traian Stanev
traian.stanev at autodesk.com
Fri Mar 17 12:11:37 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG109
Type:
Defect
Artifact ID:
MG109 (Great Circle buffer returns incorrect results)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG109 : Additional fix for inconsistent return values for GetLLAzimuthType and GetMCSAzimuthType in the case where the two input points are exactly the same. This was causing a crash.
Modified
File: trunk/MgDev/Common/Service/Geometry/Buffer/LatLonBorderWalker.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Geometry/Buffer/LatLonBorderWalker.cpp?view=diff&rev=340&p1=trunk/MgDev/Common/Service/Geometry/Buffer/LatLonBorderWalker.cpp&r1=339&p2=trunk/MgDev/Common/Service/Geometry/Buffer/LatLonBorderWalker.cpp&r2=340
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
