[mapguide][MG129][Modified] Great Circle azimuth computation is numerically unstable
Traian Stanev traian.stanev at autodesk.com
Fri Mar 17 12:14:47 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG129
Type:
Defect
Artifact ID:
MG129 (Great Circle azimuth computation is numerically unstable)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
The great circle azimouth computation code in CoordSys.cpp is not numerically stable -- for points very close to each other, like 1 foot distance for example, the math would break down and return NaN.
New value:
The great circle azimuth computation code in CoordSys.cpp is not numerically stable -- for points very close to each other, like 1 foot distance for example, the math would break down and return NaN.
-- Summary changed:
Old value:
Great Circle azimouth computation is numerically unstable
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
