[mapguide][MG130][New] Expression for label rotation not getting saved to XML
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Mar 17 12:42:06 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG130
Type
 Defect
Artifact ID
 MG130 (Expression for label rotation not getting saved to XML)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Defect Severity set to new value
  Medium
- Artifact created
- Artifact Status set to new value
  New
- Steps to Reproduce set to new value
  - assign an expression to the label rotation
- save the layer
- using the test forms look at the layer definition XML
=> the <Rotation> element is missing
- Summary set to new value
- Description set to new value
  If the label rotation is set to an expression then this expression is not saved with the layer definition.
- Subcomponent set to new value
  Core
- Operating system set to new value
  All
- Component set to new value
  All
- Platform set to new value
  All
- Priority set to new value
  P3
- Version set to new value
  1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
