[mapguide][MG130][Modified] Expression for label rotation not getting saved to XML
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 17 12:44:19 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG130
Type:
Defect
Artifact ID:
MG130 (Expression for label rotation not getting saved to XML)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Code fix has been submitted.
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Status Explanation set to new value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
