[mapguide][MG133][New] Web layouts containing JPN characters do not display correct...
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Mar 17 13:41:09 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG133
Type
 Defect
Artifact ID
 MG133 (Web layouts containing JPN characters do not display correctly in JPN OS)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Component set to new value
  Web Server Extensions
- Summary set to new value
- Version set to new value
  1.0.0
- Artifact Status set to new value
  New
- Priority set to new value
  P1
- Steps to Reproduce set to new value
  See description.
- Description set to new value
  If you're running WinXP Japanese and have a web layout that contains Japanese characters (either directly in the name or indirectly via a parent folder), then you won't be able to open that layout.  The browser will most likely show "Internal Server Error"  messages.
- Platform set to new value
  All
- Operating system set to new value
  All
- Defect Severity set to new value
  High
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
