[mapguide][MG132][Modified] Fix CopyResource API to allow copying resources from one to ...
Steve Dang steve.dang at autodesk.com
Fri Mar 17 16:16:57 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG132
Type:
Defect
Artifact ID:
MG132 (Fix CopyResource API to allow copying resources from one to another repository)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
Windows Server   unit tests failed/run: 0/378
Linux   Server   unit tests failed/run: 0/378
Windows Web Tier unit tests failed/run: 0/921
Modified
File: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.cpp?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.cpp&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.cpp&r2=344
File: trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp&r2=344
File: trunk/MgDev/Server/src/Services/Resource/RepositoryManager.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/RepositoryManager.h?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/RepositoryManager.h&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/RepositoryManager.h&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.cpp?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.cpp&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.cpp&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.h?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.h&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.h&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.cpp?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.cpp&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.cpp&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.h?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.h&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.h&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.cpp?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.cpp&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.cpp&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.h?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.h&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.h&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ResourceHeaderManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceHeaderManager.cpp?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ResourceHeaderManager.cpp&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ResourceHeaderManager.cpp&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ResourceHeaderManager.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceHeaderManager.h?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ResourceHeaderManager.h&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ResourceHeaderManager.h&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp&r2=344
File: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h?view=diff&rev=344&p1=trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h&r1=343&p2=trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h&r2=344
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
