[mapguide][MG135][Modified] Problems with log file names and archiving
Ronnie Louie
ronnie.louie at autodesk.com
Fri Mar 17 19:33:34 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG135
Type:
Defect
Artifact ID:
MG135 (Problems with log file names and archiving)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Target milestone set to new value:
1.0.0
-- Resolution Description set to new value:
Code to create the archives was not being called when the log parameters changed. Also code for extracting the archive specifier was inserting the two digit date as part of the filename is changed such that the the filename and the specifier are identified. The active log file names now match what is specified in the configuration pages. The archive frequency functionality is working as designed, and the log archives are being created as designed.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Submission Reviewed set to new value:
No
-- External ID set to new value:
752593, 752588
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
