[mapguide][MG137][Modified] MgSiteConnection::GetSite not implemented
Trevor Wekel
trevor.wekel at autodesk.com
Sun Mar 19 21:47:16 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG137
Type:
Defect
Artifact ID:
MG137 (MgSiteConnection::GetSite not implemented)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Server Unit Tests
Windows: OK (378 Tests)
Linux: OK (378 Tests)
Web Unit Tests
Windows: 921/921 passed
Sheboygan sample map is usable on Windows and Linux using Ajax Viewer.
DWF Viewer was verified using Windows server only.
All affected HTTP operations were verified through test forms
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
