[mapguide][MG130][Modified] Expression for label rotation not getting saved to XML
Ben Trumbore ben.trumbore at autodesk.com
Mon Mar 20 10:59:09 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG130
Type:
Defect
Artifact ID:
MG130 (Expression for label rotation not getting saved to XML)
Modified by:
Ben Trumbore
bentrumbore (ben.trumbore at autodesk.com)
The following modifications were made to this artifact:
-- Submission Reviewed set to new value:
Yes
-- Review Comments set to new value:
Looks good.  I will forward this change to the Map team, as they share this code.  - Ben
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
