[mapguide][MG140][New] Add additional error messages for failed server startup
Bruce Dechant
bruce.dechant at autodesk.com
Mon Mar 20 15:20:01 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG140
Type
Enhancement
Artifact ID
MG140 (Add additional error messages for failed server startup)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Priority set to new value
P3
- Artifact created
- Description set to new value
If the server fails to find the locale resource file or the unit testing Dll/SO no error message indicating the problem is give.
- Justification set to new value
The server needs to give an error message if it fails to load the locale resource file or unit testing DLL/SO.
In the case of the locale resource failing to load the server will default to trying to load the locale "en" resource file. If that fails the server has no choice but to fail to start. An error is reported in either case.
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
