[mapguide][MG72][Modified] KB912945 update interferes with DWF-Viewer-based web layouts
Alain Lebatard
alain.lebatard at autodesk.com
Mon Mar 20 16:31:38 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG72
Type:
Defect
Artifact ID:
MG72 (KB912945 update interferes with DWF-Viewer-based web layouts)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
There were 2 problems related to the IE update:
The first problem, described in the knowledge base article KB912945 is that ActiveX controls now require explicit activation by the user, unless they are created by an external script. This submission adds an external script which contains the creation of the DWF viewer.
The second problem is that the IE update introduced a side-effect that affects the EMap event relayer activeX control. When this control is created along with the DWF viewer, the later becomes virtually unusable. After various attempts to make this work, I found that a workaround is to create the event relayer in a separate frame. This submissions creates an IFrame to contain the event relayer, and the handlers related to the relayer have moved to this frame accordingly.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
