[mapguide][MG142][New] Remove "Open source' from MapGuide branding
Alain Lebatard alain.lebatard at autodesk.com
Mon Mar 20 19:22:57 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG142
Type
 Defect
Artifact ID
 MG142 (Remove "Open source' from MapGuide branding)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Description set to new value
  The current about and credential dialogs display "MapGuide Open Source". This should be replaced so no distinction appears in the UI between the open source and the enterprise version.
- Subcomponent set to new value
  General
- Steps to Reproduce set to new value
  Open a web layout in IE
=> See "MapGuide Open Source" in credentials dialog
Select the command 'About'
=> See "MapGuide Open Source Viewer", "MapGuide Open Source Server"...
- Defect Severity set to new value
  Low
- Component set to new value
  Web Server Extensions
- Platform set to new value
  All
- Summary set to new value
- Artifact created
- Version set to new value
  1.0.0
- Artifact Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
