[mapguide][MG143][New] SetSelectionXML in DWF viewer surround wrongly zoom to selec...
Alain Lebatard alain.lebatard at autodesk.com
Mon Mar 20 20:25:58 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG143
Type
 Defect
Artifact ID
 MG143 (SetSelectionXML in DWF viewer surround wrongly zoom to selection)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Defect Severity set to new value
  Low
- Component set to new value
  Web Server Extensions
- Description set to new value
  The API SetSelectionXML() in the DWF surround executes a 'zoom to selection' action, which is incorrect.
- Artifact created
- Artifact Status set to new value
  New
- Version set to new value
  1.0.0
- Subcomponent set to new value
  DWF Viewer
- Summary set to new value
- Steps to Reproduce set to new value
  There is no easy way to reproduce this one. To reproduce it:
  - create a server side script that generates an XML feature set describing features displayed in the current map, and return this feature set to the client
  - have the client-side javascript code call SetSelectionXML passing the XML feature set
--> The scale in the DWF will change
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
