[mapguide][MG144][New] MgColor is not part of the third-party API
Alain Lebatard
alain.lebatard at autodesk.com
Mon Mar 20 20:37:42 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG144
Type
Defect
Artifact ID
MG144 (MgColor is not part of the third-party API)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Description set to new value
Third party scripts writien in PHP, JSP, or ASP.NET cannot use the class MgColor
- Version set to new value
1.0.0
- Subcomponent set to new value
Web API
- Steps to Reproduce set to new value
The following PHP script fails with an error "Fatal error: Class 'MgColor' not found"
<?php
$clr = new MgColor(0, 0, 128);
echo "RGB: " . $clr->GetColor();
- Summary set to new value
- Defect Severity set to new value
Medium
- Artifact Status set to new value
New
- Platform set to new value
All
- Component set to new value
Web Server Extensions
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
