[mapguide][MG149][New] Add "None" to list of log archiving frequencies in Site Admi...
    Louise Watson
    louise.watson at autodesk.com
    Tue Mar 21 11:47:53 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG149
Type
 Defect
Artifact ID
 MG149 (Add "None" to list of log archiving frequencies in Site Admin)
Reported by
 Louise Watson
 louisewatson (louise.watson at autodesk.com)
New artifact details:
- Subcomponent set to new value
  Map Admin
- Priority set to new value
  P2
- Status Explanation set to new value
  The Site Admin gives inaccurate information.  The work around is to go to each log file and save the properties as is.
- Version set to new value
  1.0.0
- Artifact Status set to new value
  New
- Artifact created
- Defect Severity set to new value
  High
- Description set to new value
  Presently, in the "Log Properties" page of Site Admin, an archive frequency may be specified for each log.  The defect is that the UI assumes that a frequency is always specified: Day, Month, Year.  However, this frequency is stored as a special char appended to the log filename as stored in serverconfig.ini.  There is no way to insure that this filename contains any frequency specifier.
- Platform set to new value
  All
- Operating system set to new value
  All
- Steps to Reproduce set to new value
  1.  Edit serverconfig.ini such that the log filename for the Access log is Access.log.  This happens to be the default value when the server software is installed.
2.  Invoke the Site Admin and go to the Log Properties page. Select the Access log tab.
3.  Notice that the archive frequency is set to "Daily".
- Component set to new value
  Web Server Extensions
- Summary set to new value
- Resolution Description set to new value
  Add "None" to the list of possible log archive frequencies.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
