[mapguide][MG130][Modified] Expression for label rotation not getting saved to XML
Ben Trumbore
ben.trumbore at autodesk.com
Wed Mar 22 12:58:32 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG130
Type:
Defect
Artifact ID:
MG130 (Expression for label rotation not getting saved to XML)
Modified by:
Ben Trumbore
bentrumbore (ben.trumbore at autodesk.com)
The following modifications were made to this artifact:
-- Status Explanation set to new value:
Old value:
Code fix has been submitted.
*** It was discovered that this change caused the default rotation of "0" to be written out, where before it was omitted. This broke some unit tests, so the code is being changed again.
New value:
At this time no further code changes are being made. The previous fix causes the rotation element to always be written, even if the value is the default. Additional changes to eliminate that behavior could be destabilizing.
-- Artifact Status changed:
Old value:
Reopened
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
