[mapguide][MG156][Modified] Relationship between controls and AJAX viewer is hardcoded
Alain Lebatard alain.lebatard at autodesk.com
Wed Mar 22 14:02:21 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG156
Type:
Enhancement
Artifact ID:
MG156 (Relationship between controls and AJAX viewer is hardcoded)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Both LegendCtrl outer frame and PropertyCtrl script now have an optional parameter MAPFRAME allowing to create the control in a different frame. The MAPFRAME parameter specifies how to reference the AJAX viewer frame. If no parameter is specified the controls are assumed to exist in their current location, embedded in the AJAX viewer frame.
Legend control inner frames now use their parent to get a reference to the viewer frame, instead of hardcoding it.
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
