[mapguide][MG157][New] Annoyance: DWF viewer samples behaviour changed by Microsof...
Jason Birch jason.birch at nanaimo.ca
Wed Mar 22 16:01:12 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG157
Type
 Defect
Artifact ID
 MG157 (Annoyance:  DWF viewer samples behaviour changed by Microsoft KB912945 update)
Reported by
 Jason Birch
 jasonbirch (jason.birch at nanaimo.ca)
New artifact details:
- Steps to Reproduce set to new value
  Install optional KB912945 update on Windows XP (SP2) / IE6 -- possibly others -- and browse to dwf viewer sample.
- Artifact Status set to new value
  New
- Platform set to new value
  PC
- Defect Severity set to new value
  Low
- Artifact created
- Description set to new value
  When this optional update is installed, it changes the ActiveX behaviour to require that a user click on the control before it responds to input.
This can be worked around by loading the object from an external JavaScript file.  MS has implementation tips here:
http://msdn.microsoft.com/library/default.asp?url=/workshop/author/dhtml/overview/activating_activex.asp
KB Link:
http://support.microsoft.com/kb/912945
This is not limited to DWF viewer; all ActiveX controls have the same (or worse) behaviour under this update.
- Summary set to new value
- Version set to new value
  1.0.0
- Subcomponent set to new value
  DWF Viewer
- Component set to new value
  Web Server Extensions
- Operating system set to new value
  Windows XP
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
