[mapguide][MG150][Modified] Need a try / catchall mechanism in SWIG generated wrapper co...
Alain Lebatard
alain.lebatard at autodesk.com
Wed Mar 22 20:17:24 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG150
Type:
Enhancement
Artifact ID:
MG150 (Need a try / catchall mechanism in SWIG generated wrapper code)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
SWIG generation for PHP, Java and .NET was modified to add a catch(...) clause around each native method call. In this catch statement the proxy code calls a onCatchAll() function whose code is supplied by user through a file named with by new option -catchallcode on SWIG's command line.
Each of the 3 API provide a file catchall.code which contain the necessary code to create an exception MgUnclassifiedException and throw a wrapper to it to the managed code.
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
