[mapguide][MG48][Modified] Update Site Admin UI for new MakePackage feature per ECO1508...
Louise Watson
louise.watson at autodesk.com
Thu Mar 23 12:02:29 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG48
Type:
Task
Artifact ID:
MG48 (Update Site Admin UI for new MakePackage feature per ECO15088)
Modified by:
Louise Watson
louisewatson (louise.watson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG48
One more revision to the way package names are constructed when the Make Package feature is used. In this submission, the procedure for selecting the string that identifies the host in the package name was changed to use the server's Display Name whenever possible. If the display name is empty, then the server's IP address is used if it is something other than 127.0.0.1 as this is a common address which will not clearly identify the host. Finally, if the IP address can't be used, the computer's name is used if available.
In addition, code was added to insure that, if the package name contains a single quote, that the single quote character is escaped in all JavaScript strings.
Modified
File: trunk/MgDev/Web/src/mapadmin/js/scripts.js https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapadmin/js/scripts.js?view=diff&rev=389&p1=trunk/MgDev/Web/src/mapadmin/js/scripts.js&r1=388&p2=trunk/MgDev/Web/src/mapadmin/js/scripts.js&r2=389
File: trunk/MgDev/Web/src/mapadmin/packagemanagement.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapadmin/packagemanagement.php?view=diff&rev=389&p1=trunk/MgDev/Web/src/mapadmin/packagemanagement.php&r1=388&p2=trunk/MgDev/Web/src/mapadmin/packagemanagement.php&r2=389
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
