[mapguide][MG161][New] License Management infrastructure
Steve Dang steve.dang at autodesk.com
Thu Mar 23 16:11:10 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG161
Type
 Task
Artifact ID
 MG161 (License Management infrastructure)
Reported by
 Steve Dang
 stevedang (steve.dang at autodesk.com)
New artifact details:
- Description set to new value
  This artifact implements the License Management infrastructure that can be supported/extended by a MapGuide application.
- Testing Notes set to new value
Windows Server   unit tests failed/run: 0/379
Windows Web Tier unit tests failed/run: 0/921
Linux   Server   unit tests failed/run: 7/379
    (6 in Coordinate System, 1 in Geometry)
- Task Priority set to new value
  High
- Summary set to new value
- Artifact Status set to new value
  New
- Target milestone set to new value
  1.0
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
