[mapguide][MG162][Modified] Update DWF Components
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Thu Mar 23 21:24:41 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG162
Type:
Task
Artifact ID:
MG162 (Update DWF Components)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Testing Notes set to new value:
Old value:
Ran server unit tests - 378/378 passed
Ran web tier unit tests - 921/921 passed
Open Sheboygan map using DWF Viewer.  Verified graphic / object properties worked as expected.
New value:
Opened Sheboygan map using DWF Viewer.  Verified graphics / object properties worked as expected.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
