[mapguide][MG157][Modified] Annoyance: DWF viewer samples behaviour changed by Microsof...
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 24 10:09:25 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG157
Type:
Defect
Artifact ID:
MG157 (Annoyance: DWF viewer samples behaviour changed by Microsoft KB912945 update)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Priority set to new value:
P2
-- Status Explanation set to new value:
While change this to resolved once the next DWF Viewer is released.
-- Target milestone set to new value:
1.0.1
-- Resolution Description set to new value:
There are two parts to this.
1/ Fixing MapGuide's web surround to use the workaround from Microsoft - this was fixed with submission MG72.
2/ Fixing DWF Viewer - it uses embedded controls and the same workaround needs to be applied here. The next release of DWF Viewer will have this fixed (the fix for EMap has been submitted).
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Resolution set to new value:
External
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
