[mapguide][MG80][Modified] Subversion-only build fails under Red Hat 3
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 24 10:30:46 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG80
Type:
Defect
Artifact ID:
MG80 (Subversion-only build fails under Red Hat 3)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Status Explanation set to new value:
Code change was submitted.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Resolution Description set to new value:
-- Testing Notes set to new value:
The Pathan install now works correctly.
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
