[mapguide][MG159][Modified] Add client check to prevent FDO G001 providers crashing the ...
Bruce Dechant bruce.dechant at autodesk.com
Fri Mar 24 12:38:23 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG159
Type:
Defect
Artifact ID:
MG159 (Add client check to prevent FDO G001 providers crashing the server)
Modified by:
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
The following modifications were made to this artifact:
-- Steps to Reproduce set to new value:
Old value:
Try and create an Oracle connection on a machine that has no Oracle client. The MapGuide server will crash.
You can simulate no Oracle client be renaming your Oracle client folder before running the server.
New value:
Try and create an Oracle or MySQL connection on a machine that has no client. The MapGuide server will crash.
Note: You can simulate no Oracle client be renaming your Oracle client folder before running the server.
-- Description set to new value:
Old value:
Add Oracle client check to workaround Oracle FDO G001 provider crashing the server when no Oracle client is installed.
This workaround will be removed in a future submission once the regression bug inside the Oracle FDO G001 provider has been fixed.
New value:
Add client check to workaround FDO G001 providers crashing the server when no client is installed.
The following FDO providers are affected:
1) Oracle
2) MySQL
This workaround will be removed in a future submission once the bug inside FDO G001 has been fixed.
-- Summary changed:
Old value:
Add Oracle client check to prevent Oracle FDO G001 provider crashing
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
