[mapguide][MG164][New] Locale is not propagated to all scripts
Alain Lebatard
alain.lebatard at autodesk.com
Fri Mar 24 13:13:01 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG164
Type
Defect
Artifact ID
MG164 (Locale is not propagated to all scripts)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Platform set to new value
All
- Summary set to new value
- Steps to Reproduce set to new value
1. Open a file AJAX viewer. (IE)
2. Place ja file into c:\Program Files\MapGuideOpenSource\WebServerExtensions\wwl\localized.
3. Modify AJAX Viewer URL by add '&LOCALE=ja' at the end.
4. Viewer UI displays JPN charcters but some other strings are still in ENU such as
a. Tasks (top right corder) (TASKS)
b. Right click menu from Layer pane. (REFRESH, EXPANDALL, COLLAPSEALL, etc)
Problem is reproducible with IE & Firefox.
- Artifact created
- Subcomponent set to new value
General
- Version set to new value
1.0.0
- Defect Severity set to new value
High
- Artifact Status set to new value
New
- Component set to new value
Web Server Extensions
- Description set to new value
The LOCALE parameter that is passed to the initial viewer script is not propagated to all scripts, causing some scripts to be treated with the default locale 'en'
Clarfy defect 771146
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
