[mapguide][MG164][Modified] Locale is not propagated to all scripts
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 24 14:06:50 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG164
Type:
Defect
Artifact ID:
MG164 (Locale is not propagated to all scripts)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
The LOCALE parameter that is passed to the initial viewer script is not propagated to all scripts, causing some scripts to be treated with the default locale 'en'
Clarfy defect 771146
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
