[mapguide][MG164][Modified] Locale is not propagated to all scripts
    Alain Lebatard
    alain.lebatard at autodesk.com
    Fri Mar 24 16:25:00 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG164
Type:
Defect
Artifact ID:
MG164 (Locale is not propagated to all scripts)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Localization Notes set to new value:
I noticed that the JSP version of the web surround does not correctly display Japanese characters. The PHP and ASP.NET implementations work fine.
I'm not addressing this issue with this submission because it is not the same defect. A new defect needs to be open for the problem specific to JSP.
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Add the locale to the scripts where it was missing, including some scripts that currently do not need to know about the locale, for future evolution.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
