[mapguide][MG114][Modified] & Character in URL Nullifies Tool Tip
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon Mar 27 12:39:17 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG114
Type:
Defect
Artifact ID:
MG114 (& Character in URL Nullifies Tool Tip)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Developer Notes set to new value:
The MgFeatureInformation::ToXml method converts the feature data to XML form. This method is used by the AJAX viewer as part of the tooltip display mechanism. The feature data includes the tooltip, the hyperlink, and the feature properties.
The bug was simply that the ToXml method was not properly encoding the hyperlink for XML (all the others were getting encoded).
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
