[mapguide][MG65][Modified] Java API does not build or work on Linux
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon Mar 27 13:13:40 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG65
Type:
Defect
Artifact ID:
MG65 (Java API does not build or work on Linux)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Code fixes have been submitted.
-- Status Explanation set to new value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
