[mapguide][MG167][Modified] DWF surround wrongly uses relative reference to Mapagent
    Alain Lebatard
    alain.lebatard at autodesk.com
    Mon Mar 27 13:31:54 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG167
Type:
Defect
Artifact ID:
MG167 (DWF surround wrongly uses relative reference to Mapagent)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
The map agent is now invoked with a fully qualified URL. It is not harcoded though, the root folder in the path is dtermined by API.
The problem had already been fixed that way for the AJAX viewer a while back and the DWF viewer shoul have received the same fix at the time.
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
