[mapguide][MG168][New] AJAX Legend control should use more space when no property c...
Alain Lebatard
alain.lebatard at autodesk.com
Mon Mar 27 19:44:57 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG168
Type
Defect
Artifact ID
MG168 (AJAX Legend control should use more space when no property control)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Defect Severity set to new value
Low
- Steps to Reproduce set to new value
Create a web layout and uncheck "Property pane".
Open the web layout in a web browser
-> The legend control fills only half the space, and there is no way to resize it.
- Component set to new value
Web Server Extensions
- Platform set to new value
All
- Artifact created
- Subcomponent set to new value
AJAX Viewer
- Artifact Status set to new value
New
- Description set to new value
When the web layout is defined to show no property control, the legend control is displayed with a default height and there is no way to resize it.
Note that the DWF viewer initially displays the legend control similarly, but allows resizing it.
Ideally, since no property control is displayed, the legend control should fill the entire vertical space.
- Version set to new value
1.0.0
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
