[mapguide][MG168][Modified] AJAX Legend control should use more space when no property c...
Alain Lebatard alain.lebatard at autodesk.com
Tue Mar 28 12:12:24 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG168
Type:
Defect
Artifact ID:
MG168 (AJAX Legend control should use more space when no property control)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution Description set to new value:
The legend control now fills the entire vertical space when no property control is visible
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
