[mapguide][MG169][New] JSP Web surround does not correctly display Japanese charact...
Alain Lebatard alain.lebatard at autodesk.com
Tue Mar 28 19:01:19 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG169
Type
 Defect
Artifact ID
 MG169 (JSP Web surround does not correctly display Japanese characters)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Subcomponent set to new value
  General
- Summary set to new value
- Steps to Reproduce set to new value
  Open the file localized\en
Replace the current value for the VIEWERPROPS key with a valid Japanese string (current value is 'Properties')
Open a web layout
  -> The title about the property control display garbage characters, not the Japaense string
- Version set to new value
  1.0.0
- Artifact Status set to new value
  New
- Component set to new value
  Web Server Extensions
- Artifact created
- Description set to new value
  Strings localized in the localized\ja file do not show correctly in the web surround generated by the Web extension for Java.
The same strings are correctly displayed when using the Web extensions for ASP.NET or PHP
- Defect Severity set to new value
  Medium
- Platform set to new value
  All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
