[mapguide][MG170][New] Initial user selection is not always correct in Site Admin
Louise Watson louise.watson at autodesk.com
Wed Mar 29 10:26:10 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG170
Type
 Defect
Artifact ID
 MG170 (Initial user selection is not always correct in Site Admin)
Reported by
 Louise Watson
 louisewatson (louise.watson at autodesk.com)
New artifact details:
- Platform set to new value
  All
- Priority set to new value
  P2
- Artifact Status set to new value
  New
- Status Explanation set to new value
  This is an annoying and confusing bug but there is a workaround, so, I didn't give it a P1 status.
Note that the fix is quite easy to implement.
- Version set to new value
  1.0.0
- Subcomponent set to new value
  Map Admin
- Artifact created
- Component set to new value
  Web Server Extensions
- Summary set to new value
- Steps to Reproduce set to new value
  1.  Invoke Site Admin and go to the "Add User" page.
2.  Define a new user and hit Save.
3.  The Site Admin should now be displaying the "Manage Users" table with the new user selected.
4.  Hit the delete button on the toolbar.  Notice that Site Admin incorrectly pops up a message box stating that the user cannot be deleted.
5.  Hit OK in the message box to return to the "Manage Users" page.
6.  Select a user other than the user to be deleted and then reselect the user to be deleted.
7.  Hit the delete button again.  Notice that the Site Admin correctly handles the situation now.
- Resolution Description set to new value
  The problem is the initial value for a flag which indicates whether or not it's OK to delete the selected user.  This flag is initially set to a value of '1' and it should be set to 'true'.
- Operating system set to new value
  All
- Description set to new value
  With this defect, when a user enters the User Management page and the current selection is any user other than the built-in accounts, the delete function will incorrectly not be available.
The workaround is to select another user and subsequently reselect the user to be deleted.
- Defect Severity set to new value
  High
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
