[mapguide][MG125][Modified] Change layer template used in code samples for Dev Guide.
Trevor Wekel trevor.wekel at autodesk.com
Fri Mar 31 17:23:00 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG125
Type:
Defect
Artifact ID:
MG125 (Change layer template used in code samples for Dev Guide.)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Submission Reviewed changed:
Old value:
No
New value:
Yes
-- Review Comments set to new value:
file_get_contents("http://localhost/mapguide/viewerfiles/arearule.templ")
will only work when doing local development.  Take a look a GetRootVirtualFolder() in the mapviewerphp implementation.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
