[mapguide][MG175][New] SelectFeatures returns the number of features specified in t...
Arnab Ganguly
arnab.tux at gmail.com
Fri Mar 31 20:08:39 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG175
Type
Defect
Artifact ID
MG175 (SelectFeatures returns the number of features specified in the data cache size and stops there)
Reported by
Arnab Ganguly
arnab_ganguly (arnab.tux at gmail.com)
New artifact details:
- Platform set to new value
All
- Version set to new value
1.0.0
- Operating system set to new value
Windows 2000
- Artifact Status set to new value
New
- Defect Severity set to new value
High
- Component set to new value
Web Server Extensions
- Steps to Reproduce set to new value
Run a generic query using selectfeatures that retreives a a large number of features (atlesat more than the data cache size) on a feature source and check the count, then go to mapadmin and increase the data cache size and re-run the query and check the count again.
- Description set to new value
If you run a selectfeatures command against a feature source, ReadNext() doesnt seem to retrieve additional records once it hits the data cache size specified in the feature service parameters.
This was working in earlier builds.
- Artifact created
- Summary set to new value
- Subcomponent set to new value
Feature Service
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
