[mapguide][MG270][Modified] Nothing draws if point symbol is missing from the library
Traian Stanev
traian.stanev at autodesk.com
Tue May 2 11:36:43 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG270
Type:
Defect
Artifact ID:
MG270 (Nothing draws if point symbol is missing from the library)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
If a symbol library is deleted when a point layer is still referring to a symbol inside it, nothing will draw when the layer is previewed.
New value:
The desired behavior is to draw some default symbol just to show that there is data there.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
